Fuel delivery issue - Need some perspective
Backstory is while the wife was driving my 04 TT it cutoff. After consulting the forum determined it was a fuel pump issue (I was able to remove the fuse and it started up and unloaded it home).
I replaced the fuel and pumps, filter and regulator. It will drive for about two miles and then cut out. I can cycle the ignition and it will start right back up and will drive for about 2 miles and cut out again.
I took it to a local Euro guy and he confirmed it's losing fuel pressure but can trace the cause. He's claiming a wiring issue but was hoping the group might have some insight.
thanks
ijb
thanks
ijb
