Cayenne Lighted Door Sills Install
I am trying to install the sills but cannot get the wire through the hole into the fuse box area. I even tried using a wire hanger to guide it. I cannot get the plastic trim piece held down by the two screws to lift up. Is there anything else I should know, as I cannot get the wire to run up into the fuse area no matter what I try. It keeps going under the carpeting.
I have a 2013 Cayenne Turbo - anyone know if the sills are pre-wired or I am guessing they are not - and need some wiring to get the correct connections to the sills, etc...?
