Looking for extra set of turbo or turbo S wheels
Good friend of mine just bought a Macan with a similar interior and I can't get enough of it!
I like the 21" winter tires. In Annapolis the winters are mild compared to Baltimore and Washington DC. For my needs they work well. I have a range rover hse supercharge will full size all seasons and they've been great the last 7 yrs. So for my purposes the 21" winters will work fine. Plus they look a lot better than the smaller wheel size for the winter tires. Interesting comments on this thread. Thank you all for the suggestions. I have some leads for some nice 21's. We will see what happens...
I have a set of 21inch from my turbo i will be selling. They are 5 spoke silver . All have some curb rash which I have dressed up and now look ok . I would let them go for $600 and you pay shipping from California . You can mail me at jjdjrose@gmail.com
I was in the same position as you albertlee9, and I live in Annapolis too.
But since I take my '12 CTT out onto the sand / Hatteras Outer Banks NC for my spring Kiteboarding trips, I went with 19" for my winter set. Just put them on 2 weeks ago. I definitely notice a difference in the cornering & tire roll (exit/entrance ramps), but it's winter with cold asphalt, so I don't push it much now anyway. It's my 2 months out of the year to chill while driving.
I see your point of wanting to have same size rims for convenience of swapping,... but once you mount them up & use them up, when are you really going to ever do that?
=Steve
=Steve
The cayenne had summer tires on it. So i just put the winter tires (P's) it. Runs well, but i will put the summer tires on it middle march..I've got a lot of offers for 21" wheels, so to have the winter tires mounted, would be nice. Easy change after winter. I'm glad i can get an extra set without spending a lot of money...Nice 911, love the color and wheels...
Weights can fall off and tires potentially wear unevenly. If you have someone come out to swap them it's likely they'll have a balancing machine on their truck. It's worth having them checked periodically.
Sure, a whole set of additional rims is an added expense... one time. It's not like bare rubber is going to store in any smaller a space than mounted sets.
Upside is you get to have a different look for a while. I kinda like my Sport Classics for winter.
To me the downside to trying to use the same rims is the additional 'handling' they have to go through every time they're swapped. You depend a lot on the quality of work (operator skills) being done here. The tires have to be pulled off the rims with a machine.. Rim and tire bead involved here. Likewise pressed back on with a machine. Then each one has to be rebalanced. Which requires someone removing the old weights, potentially gouging the rims in the process. Or, worse, leaving them in place and adding more weights. Eventually leading to on-going balance issues and pointless expensive tire and suspension wear because of it.
Agree with all. My 2 sets are great to swap when I am good-&-ready (in my garage). No extra handling ensures no extra gouging when they clamp down on the rims. Sounds like albertlee9 wants two sets of rims too, so I do not believe that is in question for him. It's just the TWO sets of 21" that most here are debating. Personal preference in this region (winters are cake).
I like having my 21" with summer rubber, and 19" with all-seasons. I air-down to 22 lbs on my 19" for the deep sand on the Oceanside.
If I'm just on hardpack "jeep" access roads for soundside kiting, I don't need to go quite that low.
=Steve
=Steve
Are you carrying anything to bring them back up to road pressure? That was always the complication with my Jeep. Remembering to bring along a decent compressor... and hope it was still working by the time all four were aired back up. Fried more than a few harbor fright cheap ones. Misplaced others...
While I have the air suspension, it no longer has an open compressor port. The expandable spare has a compressor but I'd rather not wreck it for doing whole sets of tires and have it fail when needed.
