Support ring inside intake pipe loose on my CTT
Old 01-05-2017 | 05:34 PM
Torre's Avatar
Torre
Default Support ring inside intake pipe loose on my CTT
Hi,
During an inspection of the intake tubes on my 957CTT we found that on the drivers side the metal support ring had came off and had started travelling towards the intake manifold.
The metal ring is not supposed to be sticking out of the tube, it should be leaning against the edgde where you can see the white dot reflection inside the tube. I can only imagine what would have happened gad it got sucked into the intake.
Just thought I'd share this. Good thing to check I suppose, and quite easy.
Quick Reply: Support ring inside intake pipe loose on my CTT
