955 courtesy lights won't work
Some of you may not realize that there are "courtesy" flood lights on the bottom of the driver and passenger side mirrors. Mine never worked so I assumed the bulbs were dead.
I pulled out the old bulbs and replaced them and was surprised that neither of the bulbs looked damaged, and that new bulbs did not fix my problem.
I hooked up the multimeter and verified that ground is 0 ohms to a grounding point, and ground to the positive lead has high resistance. I have 0.02V between the brown and green wire on the bulb socket all the time, no matter what I do with the locks or lights.
Do your courtesy lights work? When do they light up?
