Fuse 12 in the Waterbox
#31
So far the 4 relay coils for secondary air, vacuum pump, and after-run pump tested good, coils draw under 0.2A, ran it 3 mins. The contacts open and close properly.
next, I wanted to look at the relay underneath the driver’s side panel the one @E_Swift is talking about.
#32
So ran the car without the after-run relay, and no more blown F12. All other relays were in place.
this tells me something is up with the after run relay and/or pump. When I tested the relay previously, all looked ok, current draw was under 0.2A, it was more closer to 0.1A
I can hear the secondary air pumps working fine and the brake booster vacuum pump working fine.
car did register an internal manufacturer fault code for the no relay condition on the after-run pump.
next step, run car without the secondary air relays, but install the after-run relay and see what happens to the fuse.
#34
That will be my next step. As per the schematic, looks like 2 wires from the F12 go to the after-run pump. Definitely one of those circuits causing F12 to blow. I just don’t know what the 2 circuits are. I’ve been driving around 2 days with the after-run coolant pump relay out, and all is working fine. No check engine light, or warning lights.
#35
So where are all 5 "404" relays located?
sounds like the after run coolant pump one is under the dash as shown in this thread, but is there only 1 or 2 under the dash, if only 1, where is the other one?. I see the 4 "404" relays on the water box, which are which?
Secondary pumps and vac pump for booster are working, but my after run pump dorsnt seem to run much, nor the fans after shutdown.
i did notice i the fans on and the puno running the other day after shutdown at home, so its working.
Maybe ita not meeting the criteria to run it? Seems like it should after every shutdown but maybe not.
does anyone know what criteria must be meet for the after run pump to work, and the fans, after shutdown?
#36
I actually found no reason to check any of the relays underneath the driver side dash, as none of them seem to be related to any of the circuits fuse F12 protects. Not sure where @E_Swift traced a circuit there.
