Driver door latch for kessy CTT needed or other ideas?
Have an 04 CTT and have the issue where the system doesn't believe drivers door is open even when it is (no dome light, no door light, fear it's messing with the Kessy/making the battery run down after a few days, which is another symptom). The keyless does work on the drivers door as does the button to lock.
I've read in a few posts that the driver assembly latch should be replaced/a bad microswitch or something and hoping if someone can confirm if this part number will do it:
part number 955 531 015 07 cayenne.
But I think I need a specific latch that includes the Kessy? If so does someone know that number and where to buy. I can't figure it out so far... Thanks!
When I placed "kessy" in the search bar this is what I found. I don't own a CTT just thought it might help. Good luck.
http://www.sunsetporscheparts.com/po...name=lock-assy
When I placed "kessy" in the search bar this is what I found. I don't own a CTT just thought it might help. Good luck. http://www.sunsetporscheparts.com/po...name=lock-assy
