World Premiere: The new TECHART Magnum Body & Power Kit // TAG Motorsports
Premium Sponsor
At TAG Motorsports we have a huge variety of vendors we count on to provide you, the customer, the quality and styling you would come to expect. Techart is the pinnacle of both. Having done numerous aero kits across multiple platforms (including our own 991 Turbo S) we can tell you first hand that this kit will no doubt blow you away.
This new Cayenne Magnum Kit, to be officially unveiled at the Essen Motor Show later this week, is not only stunning but completely functional. For a little more about this kit, we thought who better to describe it than it's creators.
"The new Magnum front part is hallmarked by firmly shaped surfaces. The side air intakes, the bumper
and the front spoiler are seamlessly modelled and surrounded by the typical TECHART shape.
In its center, the front apron design and the splitter, which is optionally available as carbon fiber part,
visually reduce the Cayenne’s height and create the impression of a solid, wide stance appearance.
This is enhanced further by the prominent wheel arch extensions and side skirts. The central radiator
grill merges with the side air intakes. “Airframes”, visually hovering ducts in the air intakes, include the
TECHART daytime running light units. The shape of the Airframes invoke images of aircraft engine
intake systems. The modular construction of the complete Magnum front apron provides many
possibilities for further accents such as parts in custom color or carbon fiber.
The TECHART Aero Engine Lid is entirely made of carbon fiber and features a distinctive, dynamically
shaped styling. The lid incorporates two air outlets and it is available in body color as well as in matt or
high-gloss carbon fiber finish.
The rear of the new TECHART Magnum sets design highlights with side air outlets reinterpreting the
Airframes of the front apron. The rear diffusor is an essential design element. As an option, it can be
enhanced in contrasted color or carbon fiber finish.
Newly shaped TECHART sports tailpipes are made in a hybrid structure design. The tailpipes are made
of carbon fiber, surrounding inner stainless steel pipes. The tailpipes are mounted in concave ducts
integrated in the Magnum rear apron.
At the rear hatch, a spoiler trim with an aerodynamic edge as well as an impressive roof spoiler
complete the new TECHART Magnum bodykit."
To enhance the vehicle even more Techart provides solutions for Suspension, Wheels, and even interior (photos to be released soon).
"Together with the TECHART Magnum bodykit, the complete TECHART program for the Cayenne
models is at your service for further personalization and refinement.
This includes chassis options such as the TECHART Air Suspension Module »Sport«. Besides its
setup which favors more direct and agile ride height levels, the Automatic Parking Level is a unique
TECHART feature. After locking the vehicle, the body is automatically lowered significantly to create
a powerful appearance at standstill which distinguishes clearly from the series models.
Just perfect for the new Magnum: the 22-inch TECHART Formula IV wheel. Its dimension is generous,
however, it is a particularly lightweight wheel due to a manufacturing process which uses weightreducing
technologies. An individual color match offers even more opportunities to add your personal
taste: color-coordinated with your brake calipers, aligned with your interior decorative stitching,
bi- or multi-color painted, with a matt surface finish or with a distinctive wheel edge in contrast color.
TECHART handcrafted interiors are world-renowned for their extraordinary level of quality and
accuracy. This applies to the careful choice of select materials, the tasteful orchestration of colors
as well as the sense of design and the unmatched precision and craftsmanship of the TECHART
leathershop. You might prefer to set some selective highlights to your Magnum interior. Or you might
entrust us to create your custom-made interior according to your very personal perception and taste.
Such as the exquisite TECHART interiors, created of unsurpassed supple, natural leather hides.
The capabilities also include TECHART carbon fiber surfaces, TECHART sport steering wheels in
individually combined materials and colors, personalized instrument dials, sports pedals or illuminated
and personalized door entry guards."
Now that we've covered the styling, we can move on to performance. Techart Powerkits are some of the most sought after in the industry. Again, to cover the technical specs we turn to the Techart to better explain what this kit can provide.
"Three TECHART engine powerkits are currently available for the TECHART Magnum, which increase
the power output by 26 kW / 35 hp (TA058/SD1 for Cayenne S Diesel), by 59 kW / 80 hp (TA058/T1 for
Cayenne Turbo) or by even 132 kW / 180 hp (TA058/T2 for Cayenne Turbo).
In the new engine enhancement kit TA058/T2, TECHART’s intelligent engine management system
TECHTRONIC works together with the standard engine control unit of the Cayenne Turbo and
coordinates the interaction of the engine and the new TECHART components. These include
TECHART high performance exhaust manifolds and highly efficient TECHART turbochargers
with ball bearing compressor/turbine shafts. The proprietary developed components use the exhaust
energy particularly effectively. The turbochargers increase the air throughput significantly and are
characterized by both, a highly dynamic response with a rapid boost pressure build-up, as well as
high stability. Other TECHART modifications are the optimized oil and water pipes and the sport air
filters for an unthrottled intake. In conjunction with the TECHTRONIC auxiliary control unit a specific
wiring is used for data communication with the motor sensors.
The TA058/T2 powerkit increases the engine power of the Cayenne Turbo from standard 520 hp
to 700 hp. The maximum torque increases from 750 Nm to 920 Nm. The power delivery is regulated
in two stages: during normal operation, 640 hp are available under full load. By pressing the
Sport button (standard in all Cayenne Turbo models), the full 700 hp are unleashed between
5,400 and 6,000 rpm. The maximum torque is available from 4,400 rpm.
The significant power increase allows impressive performance. For the new TECHART Magnum
based on the Cayenne Turbo, the gap between zero and 100 km/h is only 4.1 seconds.
Top track speed: of 295 km/h."
To help show off just how good this system sounds we've included a couple sound clubs for your enjoyment.
CLICK HERE For Outside Acceleration Sound Clip
CLICK HERE For Outside Driving Sound Clip
CLICK HERE For Onboard Acceleration Sound Clip
Without further adieu, we would like to present the full Techart Magnum Kit, for the Porsche Cayenne.
What do you think? If you have any questions at all regarding any of the parts you see, please feel free to contact us by clicking HERE or give us a call at 877-523-6747.
TAG MOTORSPORTS
866-793-5490 x1192
web: www.TAGMotorsports.com - email: sales@tagmotorsports.com
Authorized Dealer For: HRE, Vossen, TechArt, AWE, Bilstien, KW, Akrapovic, Capristo, Fabspseed, BBI, Vorsteiner, Milltek, 1016 Industries, BBS, Brembo, GMG, H&R, Pirelli, Michelin, Hankook & more.
TechArt & AWE Tuning's #1 Volume Dealer Nationwide
866-793-5490 x1192
Understandably none of this is on your website, probably until after the World Premier Essen Motor Show,... but can you answer some basic questions?...
Will some or all of the "kit" products be sold separately, such as the aero engine lid, rear hatch spoiler, etc?
If you only wanted to upgrade the front end, and for example already had a 958 Porsche Sport Design Package, with existing paint-to-match Arch Extensions,... would it be possible to upgrade to the TechArt front bumper, and have it use a more narrow {TechArt} arch to connect up to the existing Porsche wheel arch?
..... or are you forced to add the side skirts all the way to the back of the vehicle, all 4 wheel arches enlarged with the wider TechArt Arch, and thus forcing the entire car to be wrapped?
TIA
TIA
Premium Sponsor
TIA
TIA
So initially - the TechArt Magnum bumpers are typically going to only work with their fender arch extensions. They did the same with the Panamera Grand GT but after a bit, they produced the bumpers for a non-widebody car
Regarding some of the other bits, you will be able to add the rear spoiler, DRL kit, Hood, etc, without needing to purchase the entire kit. Those will all be separately ordered.
If you have ANY Questions at all - give us a call at 877-523-6747
