2012 Cayenne water leak resolved - developing issue?
Picked up a CPO 2012 V6 two weeks ago. Driving home I heard a water sloshing sound. Quick Rennlist search suggested clogged drains - the usual culprits. Then I noticed the passenger side floor was wet. Took it to dealer the next day, where they diagnosed a failed factory sealant along the passenger side cowl at the intersection of three seams. They had seen this once before. Apparently a robot is failing to fully fill the seam.
Dealer had to send the car to a body shop. I saw the bill, $1,100 mostly for labor. Nearly the whole front body assembly had to come off; bumper, headlights, etc., to apply $30 worth of goo. This price did not include the dealer work, which was easily 4-5 hours. All told I suspect the total was about two grand. All covered of course, with a Boxster S loaner car for the duration (no, that was not me doing charity laps at VIR, honest).
Here's the kicker - same dealer just found the same problem in another CPO Cayenne! Service manager's theory is the leak starts if the car is parked outside for an extended time, like on a sales lot. It has rained quite a lot in NC this fall so this is not unreasonable, and my car shows no evidence that this had been a long-term problem.
So the moral of the story: if you hear water sloshing about in your second gen Cayenne, get it checked fast. Bad robot!
Have any other '11-'15 owners seen/had this problem?
It was a b*tch to figure out where the leak was and to get too, but eventually with a generous amount of PF-207 Rubber able to seal it all up.
It solved all my electrical gremlins and battery drains.
Good luck with the water pump, I did the timing belt a while back and included a new water pump as part of the repair kit. Is your engine chain or timing belt?
So my sunroof drains are clear on my 16 CD but after a heavy heavy rain a week ago (my cd has been sitting in the same spot for 2 weeks); I noticed under the carpet, the padding is wet & the floor board has water.
Thoughts?
Thoughts?
