295/30/22 Nexen Tire Air Pressure ??
Old 10-07-2015 | 10:00 AM
PupC's Avatar
PupC
Default 295/30/22 Nexen Tire Air Pressure ??
Had my CTT 3 weeks now... Mornings are cold her already in Maine, 40 degrees... I notice a little wobble in front tires when cold , first 1-2 miles.. Being new to me, wondering what I should be running for air pressure in the new Nexen 295/30/22 Tires...
Pup
Old 10-07-2015 | 10:22 AM
mtnrat's Avatar
mtnrat
I have had some experience with nexan tires. The First set came on a set of sport tecno wheels I bought used. The tires were almost new so I thought I would just run them for the summer. I could never get them balanced. I even used road force. Turns out two of the tires were defective. The tire guy was going to order me two in to replace. I asked with those tires what are the chances of getting a defective tire again. I was told that there was about a 30% chance of getting another bad one so I just put some bridgestones on. Perfect. The second experience is a set of 22's came on my CTTS when I bought it as the PO wrecked the front rims and replaced them with 22" wheels with nexan roadian. They also could not be blanced. Only at 70+ mph were there slight vibrations. THe bottom line is that they are cheap chinese tires and they cost almost nothing for a reason. I have also had the same issue with cheap rims. Had a set go out of round. I think the weight of the cayenne contributed to that. Ended up pitching those suckers. Got oem for rims and some descent tires and all is good. If a person just hast to have 22's get good rims, but they are not cheap. Good luck. It was a pain for me until I got my wheel and tire problems sorted out.
Old 10-09-2015 | 01:33 PM
primm907's Avatar
primm907
Same experience thus far. Not completely sure if it's the Nexen tires or the 22's; probably a combination of both, though. I'm just going to have the OEM 21's powder coated this winter and put some decent rubber on them once I've worn out the 22's. Should still look decent with some spacers as I've already got a lowering module in place.
Quick Reply: 295/30/22 Nexen Tire Air Pressure ??
