100k on a Cayenne S. Any Life left?.
#31
Started with hearsay from mechanics. Learned about the issue on this forum and decided to get to the bottom of it. I don't want to go into too much detail right now but after spending a few days with a list from the DMV with registered CS's in the area, I was able to come to a pretty solid conclusion with these statistics.
I am fortunate to live in (and own a Cayenne from) an area that barely sees temps below freezing (SC)...of course that means I get the info display screen issue, but much better than an engine turned boulder.
#32
Is that issue fixed in the new generation V8? or the same applies?
#33
It was fixed with the 957 V8. While you still do see scored 957 V8's, they are much more in-line, occurrence wise, with the other motors that Porsche produces.
#34
Formerly 'slevy951'
#35
Can't most modern cars, if well taken care of, go at least 200-300k on the ODO? My brothers truck is pushing 275k, but he's taken well care of it thus far and its still on its original motor (2 clutches however).
#36
Totally agree. No excuse for anything less. If replacing belts,pumps, other wear items then such a high end vehicle should go at least 200-300k.
#37
I have no doubt the CTT's motor will outlast the rest of the car.
#38
Sure - plenty of Porsches out there running around with 300k+ miles on original motors. The interiors will show very little wear, too, if taken care of. None of my Honda's or Acura interiors ever held up that well. Or the motors for that mater. Head gaskets, base gaskets, cracked manifolds - you rarely hear of block issues on Porsches compared to accessories and sensors. And this is with many of the cars making twice the factory rated HP.
#40
Cheers,
TomF
#41
From where did you get this information? Last I heard there was a TSB indicating that the honing process changed in 2013, but no one has actually posted it (no longer on Renntech due to copyright issues).
#42
It was in a TSB posted in a thread here. I suspect it has been removed as well. IIRC, it was engines manufactured after April or May of 2007 that benefited from the new process. I checked mine at the time of the thread and it fell into the earlier category, which was disappointing. I'll see if I can find the thread.
Cheers,
TomF
Cheers,
TomF
#44
Engine - Crankcase/Piston/Piston Ring Replacement Info.
Service
1
25/13 ENU 1010
Jun 20, 2014
The present document was valid at the time of print. A later version may be available online
Crankcase/Pistons/Piston Rings Need To Be Replaced - Mixed Installation Is Not Approved (25/13)
Model year:
as of 2008
Revision:
This bulletin replaces bulletin Group 1, # 25/13, dated June 11, 2013. Section "Information - Spare Parts Requirements" for pistons and piston rings: Text changed to "now available again".
Vehicle Type:
Cayenne S (9PA)/Cayenne Turbo (9PA)/Cayenne Turbo S (9PA)
Cayenne S (92A)/Cayenne Turbo (92A)
Panamera/Panamera S/Panamera Turbo/Panamera Turbo S
Concerns:
Cylinder liner in crankcase
Information:
If piston rings/pistons or the crankcase need to be replaced, a mixed installation can damage the cylinder liner.
NOTICE
Combination of piston rings and crankcase.
^ Risk of damage to cylinder liner.
--> Observe specifications for permissible combinations.
Due to
^ modified production methods during the manufacture of the crankcase --> from smooth honing to structural honing
^ and the use of a different coating on the piston rings (now DLC-coated)
only the combinations specified below are permitted.
--> Before carrying out any other work, check whether the cylinder liners are smooth-honed or structurally honed:
Date of Introduction:
Only engines with structurally honed cylinder liners are used in vehicles as of the shown engine numbers:
References:
--> 101055 Replacing crankcase
--> 131020 Removing and installing pistons
--> 131037 Disassembling and assembling pistons
92AAH1, 92AAI1, 92AAL1, 970110, 970111, 970120, 970121, 970410, 970411, 970420, 970421, 970430, 970431, 970440, 970441, 970450, 970451, 9PAAH1, 9PAAH7, 9PAAI1, 9PAAL1, 9PAAL7, 9PAAN1, 9PAAS1
Model year as of 2008
C02, C36
