Heating/cooling fan goes out
Old 08-24-2015 | 08:25 AM
mikew968's Avatar
mikew968
Default Heating/cooling fan goes out
This is the 2nd fan unit to fail. Does anyone else have this issue? Not sure of cause of first failure but we had a heavy rain and the drains for the roof water may have been less than perfectly clear as the cabin air filter was soaked. Looks like the electrical unit got wet.
Old 08-24-2015 | 12:28 PM
touareg's Avatar
touareg
I thought some people in the past had problems with the speed resistor frying, and that will mess with the fan.
http://www.ecstuning.com/ES1452933/?...FZYWHwod2qEJuQ
Never had that problem, just replaced the fan.
Old 08-24-2015 | 08:55 PM
mikew968's Avatar
mikew968
The fan would not work in the vehicle but when removed and you applied voltage the fan would run so the issue was the fan motor control module (or whatever they called it) and it wasn't serviceable. Now less than a year later the same issue. Maybe they will warranty the part????
Old 09-23-2015 | 06:36 PM
mikew968's Avatar
mikew968
Porsche warrantied the part as it has a 2 yr parts warranty!
Old 09-24-2015 | 09:12 AM
Hal 2000's Avatar
Hal 2000
+1 on Resistor.
You have to take the glove box out.
Quick Reply: Heating/cooling fan goes out
