intermitant cruise control
Old 08-23-2015 | 11:19 AM
David Wilson's Avatar
David Wilson
Default intermitant cruise control
Driving along with cruise control on and it will turn itself off after about 20 or 30 miles. Since this started I have replaced battery which seemed to help for a while, but now as bad as ever. I have also replaced brake light bulbs, no help. I have also changed coils and plugs. Does anybody have any suggestions?
David 2006 CayenneS
s
Old 08-23-2015 | 04:24 PM
snzuloz's Avatar
snzuloz
There is usually a switch on the master cylinder that controls the "secondary circuit". This is what shuts off cruise when you apply the brakes. Not sure if the Cayenne has the same switch setup, most vehicles are separate from the actual brake light switch. Might be worth a look...
Old 08-23-2015 | 06:17 PM
David Wilson
Thanks Znuloz I`ll check it out.
David
Old 09-06-2015 | 11:03 AM
David Wilson
I had the stop light switch replaced. This seems to have fixed the problem. Thanks for the help.
David
Quick Reply: intermitant cruise control
