Oil Change with MityVac in Cayenne
Hi Guys,
I searched the boards and didn't see anyone posting a thread about changing the oil on a Cayenne using a MityVac. Does anyone have experience changing oil using one? I have a Mityvac that I used to change the oil on all my previous vehicles because of how easy it is.
I open the oil dipstick, enter the tube, and suction all the oil out. I then pull the plug and let any remaining drops drain out the bottom. I find it to be much less messy and easy to do in the driveway. Does anyone see any risk in doing so???
Porsche recommends against this kind of oil change procedure, and I agree with them. You'll do a better job of draining the oil and any debris using the drain plug(s).
In general, if the motor was not set up for the extraction method (e.g. the extractor will be at the lowest point of the oil pan) you run the risk of not getting all the oil out and leaving crud and debris in there to contaminate the new oil. Pulling the drain plug after extracting all the oil does you little good as there is no flow to help bring the bad stuff out.
If your car has a drain plug, that is going to be your best method of draining the oil in the most effective manner.
If the extractor hits the bottom of the pan, it should get any contaminents. One reason oils should be changed warm is that the contaminants that may have dropped out of suspension, will be picked up and more will come out (whether by extraction or drain) than if done cold.
That said, depending on the model, the extractor may not benefit you. With the V6 you have to pull the entire undertray anyway to get to the oil filter.
I`ve used fluid extractors in the past on jetski`s - no option as there`s while there is still a drain plug on the engine their is no way to access it through the hull
Always felt it was the inferior way to do it - I mean how do you know when the extractor hose is at the (optimum) lowest point? And I`m still sceptical that it will remove contaminants as well as draining via the drain plug will
Gravity is your friend in this instance and if you have to access the filter from below whats the advantage?
The TopSider oil extraction tool is what I've been using on our cars. It does get nearly all the oil out of the sump.
For the 993, it's just a lot less messy and even though I still open the drains, less than a cup comes out. The BMW E46 has even less remaining. I had to replace the oil pan gasket and the sump was empty after sucking the oil out. The sump was also very clean as well after 155K miles.
The Cayenne gets the same process and don't see any worry of using the Top Sider. For me, it's less chance of a deluge of oil missing my drain pan!
Hi Guys, I searched the boards and didn't see anyone posting a thread about changing the oil on a Cayenne using a MityVac. Does anyone have experience changing oil using one? I have a Mityvac that I used to change the oil on all my previous vehicles because of how easy it is. I open the oil dipstick, enter the tube, and suction all the oil out. I then pull the plug and let any remaining drops drain out the bottom. I find it to be much less messy and easy to do in the driveway. Does anyone see any risk in doing so??? Thanks
Hi Guys,
