2003 C TT A/C doesn't work. Fault 1592 : Air quality sensor
Old 05-05-2023 | 03:01 PM
  #31
joeccl's Avatar
joeccl
2nd Gear
I have th same problem and I changed the inlet temperature sensor (access from under glove box). It doesn’t work at the beginning, but it start working after 5 mins drive at about 30 mph. Hope this help.
AJones 78 (05-10-2023)
Old 06-10-2023 | 07:33 PM
  #32
Shaun @ Tru6's Avatar
Shaun @ Tru6
Very helpful thread. I have a 2010 and been getting code 1592. Just put the 95561855002 in under the wiper cowl. Pulled out what I think is 95557230400 behind glove box but the replacement I got from the dealer is different. See pics. Did I pull out the wrong sensor or get the wrong sensor or both?
Old 06-10-2023 | 07:35 PM
  #33
Pkcayenne's Avatar
Pkcayenne
Default This is the correct one
Old 06-10-2023 | 07:47 PM
  #34
Shaun @ Tru6
Nothing showed up if you were posting a pic but apparently I got the superseded 958 part number which fits 2003 to 2018. So I'll plug it in.
Old 08-24-2023 | 06:49 PM
  #35
VulcanGrey's Avatar
VulcanGrey
I also received a sensor like the one you received. Did yours plug in and work? The connector having 2 tabs makes me think it won't plug in to the 90deg sensor with the slot for one tab!
Old 08-28-2023 | 04:51 PM
  #36
Shaun @ Tru6
I have two sensors now, I need to remove the glove box, I think, for one of them. Going to tackle this weekend.
Quick Reply: 2003 C TT A/C doesn't work. Fault 1592 : Air quality sensor
