my TransGo! shift kit install
Old 07-28-2015 | 09:47 AM
phL's Avatar
phL
Originally Posted by mtnrat
Many modern transmissions are like this. I think it is because they are closed systems??? I would drive on to 2x6's and put it to the highest setting. Remove the plastic guard, crack loose the filling plug, hook up the durametric and run it up to about 35C running it through the gears every so often. Then I would remove the fill plug and have the tranny fluid ready in an oil hand syringe. When it got to 39C I would pump it in till it flowed out the fill hole. I would keep flowing a little more as it got to 40C and I would put the plug back in. Not like the old way at all, but it is what it is.
yeah, it's not too bad.
on other sealed trannys they go by "fill in what comes out"
but here there is quite some spill involved.
IMHO the durametric is not essential, if you figure out a way to put a thermometer in the oil
the refill with pump and hook works better than through gravity and a fill hose.
Old 03-16-2017 | 02:28 AM
Just_Dirty's Avatar
Just_Dirty
Is this an alternative to getting the Revmax valvebody?
Old 03-16-2017 | 11:39 AM
nodoors's Avatar
nodoors
Yes
Old 03-31-2017 | 08:45 PM
nrddct's Avatar
nrddct
excuse my ignorance but what symptoms would you experience that would lead you to need a shift kit?
Old 03-31-2017 | 09:22 PM
nodoors's Avatar
nodoors
hard, delayed upshifts and downshifts primarily
Old 04-04-2017 | 11:21 AM
Brainz's Avatar
Brainz
Very nice writeup. I did the same job a couple years ago. Note that in addition to this writeup, you can find the repair manual for our transmissions online. That was a nice reference for torque values, etc. Separating the valve body halves is not for the faint of heart - - there are lots of little check valves in there. But it's doable if you're careful and meticulous. Cleanliness is next to godliness, but note that the VB will leak ATF for eternity. I did all my work on a fresh aluminum drip sheet to keep the mess and parts contained.
Old 04-10-2017 | 01:27 PM
AO's Avatar
AO
Supercharged
I installed this kit a few months ago, and while it helped my 2-3 shift, it made the 5-4 shift much worse. It was worth a shot, but I think I will get a new or rebuilt VB and just swap it out.
Old 04-11-2017 | 01:03 PM
Just_Dirty's Avatar
Just_Dirty
What were your observations post install? Does the car shift better?
Old 04-11-2017 | 02:48 PM
AO's Avatar
AO
Supercharged
As I mentioned, in some gears it helped (particularly the 2-3 shift), but now the 5-4 downshift is worse. Given the amount of time it took to do the install, I don;t think it's worth the gamble. If I could re-do given what I know now, I'd skip it and just get the rebuilt VB from RevMax or someone else. I think you can swap out the VB in about 4 hours start to finish. It literally took me 1 full day on the bench to do the TransGo kit. Lots of little parts and because i'd never done a VB before, I was extra careful and slow.
Old 04-11-2017 | 02:58 PM
J'sWorld's Avatar
J'sWorld
deleted
Old 04-11-2017 | 05:40 PM
nodoors's Avatar
nodoors
Originally Posted by Mr. Haney
FWIW, you can get all new updated solenoids from Rostra controls as well as others and there is no need for a new valve body or the transgo kit.
Do you have a source?
Cool article I found searching a bit. Though this is focused on the 09G, they say much of it holds true for the 09D:
http://www.rostratransmission.com/ai...t-controls.php
Old 04-11-2017 | 05:42 PM
nodoors's Avatar
nodoors
http://www.rostratransmission.com/re...id-a-and-b.php
Old 04-11-2017 | 06:46 PM
phatz's Avatar
phatz
Interesting
File Type: pdf
Old 04-11-2017 | 06:49 PM
phatz's Avatar
phatz
Take a look at the pdf I attached, and the adjustment screw reference.
Unfortunately you need to open her up again.
Old 04-11-2017 | 08:38 PM
J'sWorld's Avatar
J'sWorld
deleted
Quick Reply: my TransGo! shift kit install
