PCV Valve repair
Silicone and hot used motor oil are not compatible. The silicone will break down. Whatever is used to make a new diaphram could be sucked into the drivers side turbo if it fails. Heluva risk for 50$.
Aren't you referring to the AOS diaphragm, not the PCV? I believe the PCV feeds into the AOS...or vice versa but I could be wrong.
As an FYI i just saw that you can buy the cap, diaphragm, and spring assembly on Amazon for $60. I know my AOS cap got a little messed up last time I took it apart so I'll prob go with that in the future.
