Headlight Question. Sorry if too dumb...
See attached image. I bought the highlighted bulb to replace the low beam (upper and outermost bulb on headlight). The system is also giving me the warning "check dipped low beam bulb" (or something close to that).
Problem is that when I went to replace the light, the housing / socket / whatver looked nothing like the unit in the package.
Thoughts? Are there different low beam purchasing options??
Thanks.
Dave
http://www.pelicanparts.com/catalog/..._pg1.htm#item0
Thanks.
Dave
The V8 Porschephile
The bulbs are identical. On the old bulb, there's a plastic sheath that surrounds the bulb base. You have to pry this open and re-install it on the new lamp. Make sure that you don't touch the glass part of the bulb with your fingers.
Thanks Andy. Something seems wrong tho. Can you tell me which light I need for low beams bulb? H7 or D1S?? See closer-up image. I bought the D1S. If itis the D1S, then I am to remove the balast, and replace the bulb housing with the buld housing on the current light??? NOTE - I don't see any headlight upgrades on my cars VIN build sheet. Gracias. Dave
The V8 Porschephile
Dave,
If you have the Bi-Xenon light package, you'll need the D1S bulbs (High & Low) otherwise, the H7 for standard Halogen lighting (High & Low). Always change both bulbs simultaneously.
Check your owner's manual on how to replace the bulbs:
2008+: Page 377 upwards
2004-2006: Page 312 upwards
Yeah. It got dumber. I went to replace the bulb again and noticed the filament was intact. So not a buIb issue. Then I noticed the headlight wiring plastic coating was cracked, flaky and much missing. I betcha that's the issue. I checked online and apparently cheap flaky wiring has been an issue on Headlight assemblies for porsche and vw. Crazy.
Anywsy, my gts is still under warranty, so I'll see if they'll fix...if not, I have some liquid electrical tape that I'll apply to the wire to keep em from sparking.
I'll post results.
Thanks all (andy),
Dave
I'll post results.
Thanks all (andy),
Dave
