battery time...2006 CS....hints, tips?
battery barely cranked over today after leaving door open with engine off.
is this a dealer item as im sure codes and such will need to be reset.
any guidance appreciated.
thank you
thank you
Battery is farily simple to do.
Here's a how-to with pictures.
http://www.pelicanparts.com/techarti...eplacement.htm
The only tricky part is finding the correct battery. I think the factory battery is a size H9, but I ended up going with a size H8 from Advance Auto for $185.
If you wind up going the Advance Auto route be sure to search online as there are usually $50 off coupons floating around. You'll need to order online with a store pickup but that's not a problem since you need to go to pick it up anyway.
If you have convenient access to an Interstate battery store, they sell a H9 that fits perfectly and is very reasonably priced at just over $200. Comes with the excellent Interstate warranty as well. The only difference from factory battery is that it's not an AGM design.
Basic Sponsor
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
was told to cross reference with a VW Toureg v8 model.
needs to be 95-110 amp hrs.
the vw dealer had one for approx $210. not sure if it was an exact match.
maybe someone can verify the direct replacement.
**Edit**
So I hit the Google to educate myself. So is an AGM battery recommended for the Cayenne?
was told by porsche tech that a 2006 CS is not an AGM style battery. that type battery came on the next generation cayenne.
2006 still had the older style battery correct? is tech right?
also, if i do a battery install myself, will codes show up or will i need to do a reflash at the dealership?
Lifetime Member
Lifetime Member
But AGM will last longer. My CS's first battery lasted 9 years. At $135, just get the real thing from VW (~$200). Small expense considering it will take you 60-70k miles. Also, being that it is under your ***, I like the idea of it operating at a cooler temp and not leaking acid...
Lifetime Member
Lifetime Member
Either way, I have never seen a traditional battery that did not at some point leak, which is not what I would want occuring INSIDE my car, under my seat.
Just watch the video I posted, do exactly what it says, and for $200 you'll have a battery in there which will last you probably 6-7 years or more.
