Pulsing / Clicking by Brake Pedal
7th Gear
Hello all!
After exhaustive searching, I am unable to solve an issue I am experiencing with my 2006 Cayenne TTS (120,000mi).
I am experiencing an intermittent high speed clicking or pulsing by the brake pedal area after a hard right hand turn. Not during the turn but after the vehicle straightens out. Sometimes it happens while going straight in a parking lot. It doesn't happen between shifts. It happens very quickly, and sporadically. The vehicle does not surge while this is happening as well.
I have replaced the following with new:
Transfer Case Stepper Motor
Transfer Case Fluid
Cardan Shaft
Tires
What else should I investigate? Valve body? ABS Pump?
Thanks in advance!
Transfer Case Fluid
Cardan Shaft
Tires
Thanks in advance!
7th Gear
Hello All!
I now have a Durametric Enthusiast cable. I have checked for faults and have none.
Does anyone have any suggestions on what to take a look at using the Durametric?
Thanks!
Thanks!
7th Gear
