Codes Question
Old May 19, 2015 | 09:00 PM
8202632's Avatar
8202632
Default Codes Question
Have a really stupid question. If an electrical part has failed, should it be assumed that a code will exist in the system? It is a hard and fast rule?
For example, my auto headlight sensor. I've noticed many times now that the headlights will come on in the bright sunlight when they shouldn't. This happens intermittently (and no my DRLs are not set to "on").
So will a code show up? If not, does it have to wait till complete failure? If no code is thrown, will a technician simply report that the fault cannot be replicated?
I have another issue with my compass not being displayed about 1/2 the time and the dealer usually responds that they cannot diagnose.
Any help and insight would be appreciated
Old May 19, 2015 | 10:01 PM
gnat's Avatar
gnat
It depends on the part and the failure.
For example if there is an issue with the leveling system for the headlights, that will throw a code. If a window regulator goes, however, you won't see a code.
For the headlight issue, make sure the glass over the light sensor is clean and not chipped.
No specific ideas about your compass issue. Sorry.
Old May 20, 2015 | 05:45 PM
8202632's Avatar
8202632
Thanks!
