Fault Codes....hard starting
Old 04-20-2015 | 11:19 PM
rmslay's Avatar
rmslay
Default Fault Codes....hard starting
I have an 08 Cayenne S that has been hard to start lately. I checked the fault codes and found these. The cooling issue has to do with my thermostat housing which isn't new but the Ignition Coil D is new. Could that be the cause of the hard starting and misfire faults? How do I figure out which ignition coil is "D"?
thanks,
Richard
Quick Reply: Fault Codes....hard starting
