Picked an '11 CTT... first post is about it dying :(
IF you experience this again, try toggling the key gently as you try restarting. If you have an ignition problem, the continued trying to restart by turning the key might be causing the random success in getting it to start.
Not sure how turning the key (there's not a key though, just a plastic fake key) gently would affect the computer settings when it tries to start.
When I try to restart it, I give it several seconds between tries. I also switch off A/C, radio, etc and watch the battery voltage. So far I've gotten it restarted all 3 times it's died but after 20-30 tries, I start worrying that I'll run out of battery power.
I've had it back for a week now and no problems so far but considering it was 2 months between the 1st and 2nd time it died, I won't feel completely safe for a few months.
So far so good. Don't worry, Rennlist will be first to know if it happens again!
High Pressure fuel pump did not fix it but low pressure fuel pump and fuel control module did. Of course it may have been a combination of the 3 that was required.
Thanks David. Just curious for future TS'ing
