Can anyone identify this noise?
Hi Fellas,
I need help to identify this whistling noise where it is coming from. I'm assuming it might be the water pump pulley or the tension pulley. I changed the water pump about 3 years ago after the leak. Anyone experienced this with your CTT? Also the CEL come on. The sound comes on about 5 minutes after the engine is running. Is this a DIY fix? Any suggestions is appreciated. Thank you.
https://www.youtube.com/watch?v=R3zS...ature=youtu.be
