Photo of spare in rear storage
Can someone post a photo what is supposed to included on the right side of the spare tire? I see what looks like tire inflator but something looks missing above it. I have an 12 cayenne S.
Thanks for a great forum.
Mike
Mike
@ Mike41 - I believe that empty space in the upper Styrofoam tool-holder, is for the can of tire goo, to be used in the event you get a flat AND your car did not come with a spare. Since your Cayenne came with a spare, you do not get the can (from factory). Plus I had heard that the can only has a shelf life of 4 or 5 yrs. And it cost {dealer here in US} approx. $45!!
I've also seen the hoses that come with that goo can. It looks like it has two fitting ends, one to connect to the can, and the other end to your air pump inflator (presumably sucking the goo out of the can & into your tire valve.
Would love to hear from anyone who has done that / used that first hand.
I assume it works,... but does it make the inside of your tire & rim all sticky for the next tire change?
