cayenne v6 spark plug with oil
Old 02-25-2015 | 08:15 PM
lethalio's Avatar
lethalio
4th Gear
Default cayenne v6 spark plug with oil
Hi, i have a problem i change the spark plugs of my 2006 cayenne v6 and i notice there is some oil in the coils and spark plugs. is there any spark plug seals around and where is the location? i cant see any o rings there.... please help!!
Old 02-25-2015 | 09:50 PM
wrinkledpants's Avatar
wrinkledpants
You need a new valve cover gasket set. Includes the valve cover gasket and the gasket that seals the spark plug holes. If the spark plug hole gasket leaks, it lets in oil from the heads. Pretty common issue.
Quick Reply: cayenne v6 spark plug with oil
