Durametric module coding
Old Feb 25, 2015 | 06:59 AM
gwaimie69's Avatar
gwaimie69
Default Durametric module coding
After changing battery i now have a host of fault codes, I need to recode the level control module, can this be done with a durametric cable? Also my aftermarket stereo now has no sound. I have the bose MOST option. Please advise
Old Feb 25, 2015 | 11:06 AM
Shannon123's Avatar
Shannon123
Recode level control = yes.
Reset other faults = yes
I suspect the radio may be a victim of a fault code as well, but others will likely chime in.
Look thru this....page 12 for resetting faults
http://www.durametric.com/Durametric...ion_Manual.pdf
For access to level control, here are instructions.
http://www.6speedonline.com/forums/c...etric-diy.html
If needing to buy a durametric.......I used the syntax below in google search and found one quickly and cheap ($100) on craigslist..don't pay more than around $100 per remaining VIN (enthusiastic model). Here is one on EBAY now....priced about right, but would not pay much more (unless desperate)http://www.ebay.com/itm/Porsche-Dura..._Tools&vxp=mtr
duarametric site:craigslist.org
If when shopping for a cable....read the following closely !
Which generation cable do I have?
•First generation cables were sold through February 2008. Cables sold after February 2008, with very few exceptions, are second-generation cables.
•The cables with a box in the middle of the wire are first generation cables and are not compatible with version 6.
•Cables with the electronics inside the 16-pin OBDII connector can be either first or second generation cables:
If the cable has the LED light on the side that reads "for use on: PORSCHE," then it is a second generation interface cable and it is compatible with version 6.
If the cable has the LED light on the side that reads "Enthusiast Version" or "Professional Version," then it is a first generation cable and it is not compatible with version 6.
Old Feb 27, 2015 | 07:07 PM
pcst's Avatar
pcst
Just out of curiosity, anyone used iCarsoft i960, like this one?
Old Feb 27, 2015 | 07:11 PM
pcst's Avatar
pcst
What year is your Cayenne?
My Cayenne S needs a new battery and called the dealer to confirm whether I need a code for the navigation/stereo/radio module, was informed that MY2006 doesn't need it.
Old Apr 2, 2015 | 02:59 PM
Fpinto's Avatar
Fpinto
2nd Gear
yes, you don't need it. just changed mine a few weeks. you have still to do some tricks for the windows and steerin wheel angle... roof.... read it in the manual
