TIP1: When installing for the first time take some tesa tape and wrap it around the stud for the upper strut mount. I used enough to make one wrap. This will keep the spacers in place when you are having to go back and make damping adjustments.
TIP2: When going back to dial in the damping after your first, second or third test drive, put the front of your Cayenne on jack stands, don't just lift one side at a time to make adjustments, because you have to fight the tension from your sway bar.
TIP3: You only have to remove the
sway bar bolt, this will allow your suspension to drop enough for you to get your fingers in to make adjustments. Remember to tighten that sway bar bolt at 1g. That means wheels on, jack stands removed and vehicle resting on the suspension.
Current Settings: Front 9 clicks from HARD, Rear 10 Clicks from HARD
