Leak Detection Pump?
Old Feb 6, 2015 | 04:33 PM
ProgRockJunkie's Avatar
ProgRockJunkie
Default Leak Detection Pump?
Been having some issues, cel, sometimes car won't start after a fill up. I started another thread on vacuum leaks but wanted a new title. So anyone know the part number on this? My local indy called it a leak detection pump, apparently stuck open.
File Type: png
Old Feb 6, 2015 | 05:50 PM
XR4Tim's Avatar
XR4Tim
Actually, it depends on the brand of your carbon canister. If it's made by Dayco, you need Leak Detection Pump 95560510702. If your carbon canister is made by Expert, you need an updated carbon canister which comes with a new leak detection pump, as well as a new molded hose for the retrofit.
Old Feb 6, 2015 | 07:28 PM
ProgRockJunkie
Any way of telling which by VIN? 2006 TTS. I just fell out of CPO last year, not used to trusting an independent. I want to work with them, but this is their first real test. They did not send me away with the answer to this, just a part number, and it's not the one you gave me. I don't want to start mail ordering parts and have them be wrong. Any suggestion how to get the right part so I don't end up at the dealer after all?
Old Feb 9, 2015 | 11:49 AM
ProgRockJunkie
Codes re P2235, P2237, P0441. Any clues?
Old Feb 9, 2015 | 01:17 PM
XR4Tim's Avatar
XR4Tim
What are the last 5 of your VIN? Late VINs all used the same canister. Early '06 VINs are a mixed bag.
Old Feb 9, 2015 | 05:42 PM
ProgRockJunkie
92798.
Old Feb 9, 2015 | 06:32 PM
XR4Tim's Avatar
XR4Tim
92798.
That VIN is before the cutoff. You'll have to look at the canister to know what kind it is.
Old Feb 9, 2015 | 11:01 PM
ProgRockJunkie
Thanks, man. I'm over my head. Dropping it off at the dealership tomorrow.
Old Apr 3, 2015 | 01:23 AM
bigbuzuki's Avatar
bigbuzuki
Did you get these fault codes resolved?
Old Jun 6, 2015 | 11:15 PM
Staylo's Avatar
Staylo
Default Resolution?
icspres,
Can you share your final resolution? Was it the evap purge valve, or were there other parts involved?
Thanks in advance!
Old Feb 14, 2023 | 12:09 AM
soccerTOOLsu's Avatar
soccerTOOLsu
Default P2235 & P2237
These codes ever solved?
