Got my 958 CT Dyno'd
My understanding is the IPD plenum is for longevity and security only and doesn't produce any measurable gains in HP or torque, despite what the manufacturer states.There are threads out there to corroborate this. The stock plenum tends to deteriorate over time and the aluminum version makes sense to avoid this issue.
The benefits of the GIAC tune on the other hand... is well documented. A GIAC tune is on my list for next year's modifications.
Aloha,
TomF
Aloha,
TomF
I can tell you guys that the Plenum does work, I don't know if the HP/TRQ are measurable, but the car definitely breathes better. I noticed the car doesn't down shift when you give it enough gas to do so, it holds the same gear even if you're at low RPMs and it just spools noticeably faster than before. You can easily use 2nd gear to accelerate from a dead stop. From my "seat of the pants Dyno" it is worth it and it is more noticeable than the Secondary cat delete mod.
I shipped out my ECU yesterday to GIAC. I can't wait to feel the difference!
From an aerodynamics standpoint, it just doesn't make sense... especially at the low RPMs you are talking about. It shouldn't affect spool, or shift points, or anything like that. I'll believe it once I see the numbers! I'd be happy to go to an AWD dyno and test before and after if IPD or someone else would provide me with one for free (for this temporary testing). I just can't imagine how you can improve ~30 hp worth of aero in a Y design which isn't all that bad from the start. Yes there is some x-sectional area increase, but not enough to matter much in terms of head loss. Prove me wrong IPD!
Thanks CTT-QTR, I know how expensive Dyno time can be in the US, appreciate your efforts and taking the time to post.
IPD also claims that you can return the Plenum if you do not feel the difference. Give it a try!
UPDATE
I just got a confirmation that my ECU will have the switching capability between stock and tuned. So I will definitely have the car dyno'd with the Plenum only.
