PCM 3.0 with Aux-In, But Not on PCM Menu
Old 10-01-2014 | 11:01 PM
onewhippedpuppy's Avatar
onewhippedpuppy
Default PCM 3.0 with Aux-In, But Not on PCM Menu
I have a 2009 Cayenne GTS with the PCM 3.0 and factory iPod, USB, and Aux-In mounted in the center console. But when switching through the sources my options are only AM, FM, Sat, USB, iPod, and Disc. So despite having an Aux-In, I don't have an Aux-In. I tried hooking up an audio source to see if it auto-detects and it won't. Is there something that needs to be enabled via Durametric to make it work?
Old 10-01-2014 | 11:20 PM
957 GTS's Avatar
957 GTS
that's a bummer, man. I have an 09 GTS with aux port but works fine through Source change. No SAT option though . Someone here is bound to have a good answer for you. If you could just go ahead and wait a little longer for them to give you your answer....that'd be great.
Old 10-01-2014 | 11:40 PM
onewhippedpuppy
I'm wondering if I'm maxed out at six sources, and need to disable one. The screen really doesn't have room for seven.
Quick Reply: PCM 3.0 with Aux-In, But Not on PCM Menu
