2006 Cayenne S Cost of ownership -- inside...
I have a 2006 S and even now its in need of going to the local garage. I needed to change the gasket for the transmission and now the it seems the torque converter seal needs to be replaced. I also need to change the coolant pipes from the installed ones to the new aluminum ones. At least online this is about 585 dollars and I am guessing I could get this done at the local indy with a days work which would be about 350 dollars at the most.
