Brake pad brand for 08 GTS?
Old 08-24-2014 | 01:35 PM
jhg41977's Avatar
jhg41977
Default Brake pad brand for 08 GTS?
I need to get new pads, what have you guys found that works well? Quiet, low dust. Does anyone have the rotor thickness range?
Jim
Old 08-24-2014 | 02:53 PM
Chris51080's Avatar
Chris51080
After doing my research, with the same criteria, I ordered the Hawk Ceramic pads. I'll get them installed next weekend.
Regarding the rotor minimum thickness, there should be a measurement engraved on the center of the rotor, near where it bolts to the hub.
Old 08-24-2014 | 09:35 PM
User 4221's Avatar
User 4221
Rotor thickness is 32 - 34mm.
My experience on two Cayenne's is a consistent 33mm thickness after about 60k miles
Old 08-25-2014 | 12:55 PM
Frank 993 C4S's Avatar
Frank 993 C4S
I use OEM pads.
Old 08-25-2014 | 02:23 PM
ArneeA's Avatar
ArneeA
I'll use OEM pads after experiencing pad noise from aftermarket pads (Bosch) shifting, making those clunky noise between R to D and D to R changes.
Quick Reply: Brake pad brand for 08 GTS?
