I know it activates the suspension to move the vehicle up and down, but what is the purpose, given that the other height selector switch is there? thanks.
That button is not from the factory. Looks like something that is used with an aftermarket lowering module. I would look in the back right corner to see if there is a module attached to the wiring.
Your guess is probably right but it looks like the panel is recessed around it. So it was unusually nicely done, if after market.
What year and model is this?
It's a 2005 turbo with Porsche power and front brake option. The button sends the vehicle up and down regardless of what setting the air suspension is on
This was spot-on, there is a 40mm Gemballa lowering module attached to the wiring as suggested. Thanks.
