question about durametric Level Control coding
Has anyone changed the ride height of their 957 Cayenne by using the Coding function of the durametric, versus the Adaptation function of the durametric? I cannot find anyone making use of the Coding method, which seems simpler if I could just figure out the coding algorithm.
My 08 GTS has a Current Coding of 15551 for the Level Control Module. The settings to change the height as follows:
x?xxx: height adjustment of front wheels
+0 = -25mm
+1 = -20mm
+2= -15mm
+3= -10mm
+4= -5mm
+5= Standard Setting
+6= +5mm
+7= +10mm
+8= +15mm
+9= +20mm
+10= +25mm
xx?xx: height adjustment of rear wheels
+0 = -25mm
+1 = -20mm
+2= -15mm
+3= -10mm
+4= -5mm
+6= +5mm
+7= +10mm
+8= +15mm
+9= +20mm
+10= +25mm
If I wanted to add 25mm to the front and rear height, what is the resultant code (since the setting number of 10 is two digits...)?
Additional question: anyone with a Cayenne S or Turbo know their Current Coding number? I'm curious if it's different between models.
Thanks!
+0 = -25mm
+1 = -20mm
+2= -15mm
+3= -10mm
+4= -5mm
+6= +5mm
+7= +10mm
+8= +15mm
+9= +20mm
+10= +25mm
+0 = -25mm
+1 = -20mm
+2= -15mm
+3= -10mm
+4= -5mm
+6= +5mm
+7= +10mm
+8= +15mm
+9= +20mm
+10= +25mm
Thanks!
