Headlight washers-Replacing
Old 05-31-2014 | 06:07 PM
scottl951's Avatar
scottl951
Formerly 'slevy951'
Default Headlight washers-Replacing
Just a quick note on headlight washers. I had a leaky one on the passenger side of my '04 S. You can get to them without taking the front bumper cover off. Remove the front wheel and peel back the inner fender liner about half way and they are right there. 4 screws. 2 side screws are on slots. You'll have to remove the bottom support screw and slide it up out of the way to get to the bottom slotted screw. You'll see what I mean when you get in there. Also, you'll have to remove the headlight to get the top screw out. Hose slides on/off easily but is held in place by a clip that pops off.
Just a quicky tutorial for anyone needing to replace.
HTH.
Scott
Old 08-04-2014 | 09:53 AM
scottl951's Avatar
scottl951
Formerly 'slevy951'
Update. The washer goes in from the bottom. But, you'll have to align it from the top. I initially didnt' do this and it wasn't flush with the bumper cover. I was able to pop out the headlight and get to the top 2 bolts/scews and loosen to realign.
Quick Reply: Headlight washers-Replacing
