100k mile maintenance...anything to check other than what's in the manual?
Old 05-20-2014 | 11:54 AM
david_alford's Avatar
david_alford
Default 100k mile maintenance...anything to check other than what's in the manual?
My '05 CS will be up for 100K mile service soon. Are there any items to check/replace other than what's detailed in the owner manual?
Major items already done:
Plugs/Coils replaced at 70k (previous owner)
Fuel pump/fuel filter replaced at 75k (previous owner)
Drive shaft replaced at 76k (previous owner)
Coolant Pipes done at 83k
Control arm bushings checked/OK at 85k
Regards,
Old 05-20-2014 | 03:25 PM
TheLAW's Avatar
TheLAW
7th Gear
I'm curious to see what is mandatory versus elective per other board members, as well.
LAW
Old 05-20-2014 | 03:34 PM
bigbuzuki's Avatar
bigbuzuki
The following items, in addition to want you have already stated, would have been changed by 100k by most people.
Water pump, thermostat, fuel pumps, serpentine belt, air compressor piston seal if you have air suspension, transmission hydraulic valve block, transfer case servo motor.
Old 05-20-2014 | 04:53 PM
david_alford
thanks bigbuzuki I missed the fuel pump replacement and updated my original post
Old 05-20-2014 | 11:05 PM
PCA1983's Avatar
PCA1983
Other than the coolant pipes, would y'all say that the 957s would have the same items on this list?
Quick Reply: 100k mile maintenance...anything to check other than what's in the manual?
