Need help with some Durametric codes pls
Im still trying to work out the coolant heat in my car still no solution why it is going up and down all the time (180-220) but that´s another case......
I pulled up few codes from durametric and I was hoping that some of you could help me with those.
1. Instrument Cluster for Cayenne
Current Fault Codes
470:
CAN comfort in single-wire operation - Open circuit, test conditions are not-completed, fault is currently active and is not causing a DTC light
2. Air Conditioning
Current Fault Codes
1592:
Air quality sensor
Open circuit/short circuit to B+
3. Steering wheel electronics
Current Fault Codes
1752:
Heated steering wheel
4.Gateway K-line/CAN 2003-2004 Cayenne
Current Fault Codes
470:
5.Doors and Rear Hatch
Current Fault Codes
470:
6. Level Control
Current Fault Codes
1437:
Control position not learned
No/incorrect coding/calibration
So Any help is appreciated because here in Iceland there are not that many Porsche service centers/mechanics other than the dealer and that´s an EXPENSIVE JOKE just to think about it....
Have a great day all.
