Cayenne Wheel Arch Removal
I had a bit of a mishap in my 2014 Cayenne today and did some paint damage to the front wheel arch of the car - fortunately nothing else was damaged.
Does anyone know how hard it is to remove the front wheel arch?
Is it accessible after removing the front wheel well liner?
I want to take it off and have it repainted.
Thanks for any help.
BB
BB
The V8 Porschephile
I'm not sure about the 958 however, on the 955/957 the decorative wheel trim is held onto the fender with two-sided foam tape. Removal of the trim is performed using a hair dryer to heat the glue and facilitate removal. Some have used plastic trim removal tools as others have used dental floss to cut thru the pre-warmed adhesive.
Installation is reverse of the above using new 3M automotive-grade mounting tape onto clean surfaces.
I don't know if the painted are the same as the non-painted, but the front half of mine (that's all I needed to remove to get where I needed) was held on with compression fittings and a couple of screws. The screws are hidden by the liner as you suspect.
That doesn't look to bad. Thanks MMHZ!
