P2181 Code, No symptoms, safe to drive?
My 2010 Cayenne threw a P2181 code. car runs and drives fine, blows hot air, the left front fan is working. I live in warm South Florida. I reset code and it eventually cam back. Coolant level is fine. I suspect t-stat.
I have a trip next weekend of 350 miles, am I taking a big chance? I am do for serve is 1,400 miles, so I would like to wait to get both looked at at the same time.
Freeze Frame Log:
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 55.686 %
Engine Coolant Temperature = 75 °C
Fuel Trim Bank 1 Short Term = 2.344 %
Fuel Trim Bank 1 Long Term = -1.562 %
Fuel Trim Bank 2 Short Term = 4.688 %
Fuel Trim Bank 2 Long Term = -3.125 %
Engine RPM = 1,571 rpm
Speed (OBD) = 86 km/h
Timing Advance = 16.5 °
Intake Air Temperature = 32 °C
Mass Air Flow Rate = 38.54 g/s
Throttle Position(Manifold) = 21.569 %
Run time since engine start = 489 s
Fuel Rail Pressure = 1,533.049 psi
Barometric pressure (from vehicle) = 14.649 psi
Voltage (Control Module) = 13.968 V
Engine Load(Absolute) = 55.686 %
Commanded Equivalence Ratio(lambda) = 1
Relative Throttle Position = 14.902 %
Ambient air temp = 25 °C
Absolute Throttle Position B = 21.176 %
Accelerator PedalPosition D = 32.157 %
Accelerator PedalPosition E = 15.686 %
Freeze Frame Log:
Absolutely not! Your cayenne running at lower temperature in a hot climate will cause the engine to blow up. I would have it towed to the nearest dealer immediately and have the credit card on hand.
