P12A2 Help!
Libast (09-13-2019)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165818_e9f8a910942dfc8275019b8e271bcda6e30b377d.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165823_b9015e743694518d32ce7b7647e86f7bd7f8d074.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165827_d505d14e75c149496d77d0a283214fe8ee686c95.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165837_9450d78aa192483d0f182c08288ca2e94d41b156.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165903_a5f46fdbe6f60f9114349b30abe53cf7bf0c0ddc.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165911_c681f6dbf596d204698d2a2e1be24a99efe30276.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20191025_165916_fec7244e6d5dc42adbcaada7d22d1907dcc4a28d.jpg)
Did you find out what was causing your P12A2 CEL?
I am facing the same issue since Sep 2019. Valve cover was replaced 1 year ago, replace the rail fuel sensor last week, but the P12A2 CEL is still ON.
Noticed the Brake Booster Vacuum Hose is crack and leaking, will be replacing that this week once receive the part (95535557941). Not sure if that is the culprit.
Update: 27 Oct 2019:
Replaced (95535557941). No more CEL and fault code.
Seem like my 2009 V6 cayenne P12A2 was due to split/cracks on the join of that hose.
Engine running smooth, no more rpm bouncing up and down.
Hey guys,
My wife has a 2009 V6. She started getting code P12A2 and had intermittent surging of acceleration, but car still ran okay. Took it to a shop and they recommended changing the fuel pump, fuel pressure regulator, and fuel pressure sensor.
They changed all of that and it didn't fix the problem, the light came back on. Now they are saying it may be something related to the timing chain, but I'm having a hard time understanding how this could be. This is a very reputable shop, I just don't want to throw money after a timing chain repair (See $$$$$$$$) if that's not going to fix it.
Help!
Help!
oil air separator diaphragm
Mine went out at around 98k. I think the dealer charged about $1800, but I still had the GEICO mechanical coverage which cost me a $100 deduct. They also did a per-emptive change of a couple of the hoses in the back of the engine area.
Ok, at this point I am stumped. I am getting the same 'P12A2' error on my '08 Cayenne V6 with around 50k miles. Based on the service manual information above, I have already replaced the cracking brake booster vacuum lines, high pressure fuel pump, fuel pressure sensor, fuel pressure relief valve, new gas cap, the PCV, valve cover gasket, and intake manifold gasket, and new plugs and lower injectors while I was going through the trouble. The car seems to run fine, with no obvious symptoms. For the most part, it is only ever throwing the 'P12A2' code, but is occasionally accompanied by a 'P0442' code for a very small leak detected in the EVAP system. Do you think it could be a faulty tank vent? Or any other suggestions? If so, can anyone locate a part number or location?
Ok, I was able to grab some freeze frame data:DTC that caused required freeze frame data storage
P12A2
Fuel system 1 status
CL
Fuel system 2 status
CL
Calculated LOAD Value
18.8%
Engine Coolant Temperature
69°C
Short Term Fuel Trim - Bank 1
5.5%
Long Term Fuel Trim - Bank 1
5.5%
Short Term Fuel Trim - Bank 2
7.8%
Long Term Fuel Trim - Bank 2
6.3%
Engine RPM
681/min
Vehicle Speed
5 km/h
Ignition Timing Advance for #1 Cylinder
14.0°
Intake Air Temperature
1°C
Air Flow Rate from Mass Air Flow Sensor
4.30 g/s
Absolute Throttle Position
12.5%
Time Since Engine Start
471 sec.
Fuel Rail Pressure
3460 kPa
Commanded Evaporative Purge
0.0%
Barometric Pressure
99 kPa
Control module voltage
14.182 V
Absolute Load Value
16.9%
Fuel/Air Commanded Equivalence Ratio
0.925
Relative Throttle Position
1.2%
Ambient air temperature
-2°C
Absolute Throttle Position B
12.5%
Accelerator Pedal Position D
14.5%
Accelerator Pedal Position E
7.1%
Commanded Throttle Actuator Control
2.0%
Long Term Sec. O2 Sensor Fuel Trim - B1
0.0%
Long Term Sec. O2 Sensor Fuel Trim - B2
0.8%
P12A2
CL
CL
18.8%
69°C
5.5%
5.5%
7.8%
6.3%
Engine RPM
681/min
Vehicle Speed
5 km/h
14.0°
1°C
4.30 g/s
12.5%
471 sec.
Fuel Rail Pressure
3460 kPa
0.0%
Barometric Pressure
99 kPa
14.182 V
Absolute Load Value
16.9%
0.925
1.2%
-2°C
12.5%
14.5%
7.1%
2.0%
0.0%
0.8%
I’ve been plagued by the P12A2 code for the last few months even though the car runs fine. First I had a shop replace the fuel pressure sensor. The code went away for a few days then came back. So I replaced the fuel pressure relieve valve, but the code was still there. I then replaced both low pressure fuel pumps in the tank along with the fuel filter and fuel regulator. The code remained, so I replaced the high pressure fuel pump. Still the dang code remained. So then I replaced the fuel pressure sensor that the shop had originally replaced. Finally that cleared the code for good. My 2008 Cayenne base has 196,000 on it, so I wasn’t too upset about replacing parts that may not have needed replacing.
Is the fuel pressure sensor you replaced the same as the Fuel Rail Pressure Sensor that my scanner picks up?
The following 2 users liked this post by aka2465:
2009 Cayenne (12-27-2022),
mikefirefox (07-20-2022)
