Squeaking Brake (when brake is released) !
Old 03-01-2014, 03:22 PM
meshal500
3rd Gear
meshal500's Avatar
Default Squeaking Brake (when brake is released) !
Hello,
I've just replaced all rotors and pads and of course sensors of my 08 Cayenne. All are fine except the front right. It makes this annoying squeaking noise when the brake is NOT pressed! It happens when the car is on D and is moving slowly, so usually at traffic when I release the brake for a slow movement, it will squeak until the car gets some speed. It doesn't make the noise when I press on the break or even when the break is released on high speed. It will only make it at very low speed, lets say less than 4 m/h.
I appreciate your input. Thank you
Old 03-02-2014, 08:39 AM
CaptJim
CaptJim's Avatar
This is why I add disk brake quiet to the back of the pads. Your pads appear to be floating loose. Or, it may be just that the pads need to be set and may go away with time.
Question, specifically, what pads and rotors did you use, aftermarket or OEM
Old 03-02-2014, 08:54 AM
extanker
extanker's Avatar
many things could cause this. as stated above disc brake quiet and caliper brake lube [where required]. if it is a pulsed/timed squeak it may be a rotor [out of index] .either way...go back over your work
Old 03-02-2014, 11:25 AM
996FLT6
996FLT6's Avatar
Piston stuck? Mike
Old 03-02-2014, 11:59 AM
mudman2
Moderator !x4
mudman2's Avatar
Quick Reply: Squeaking Brake (when brake is released) !
