heated steering wheel gremlin
question: 2008S with heated seats and steering wheel. When it is off (number 0) I still feel heat in the steering wheel. I turn it to 2 or 3 and the set heats up and the wheel gets hotter but then turned back to 0 and seat is off but wheel stays on although at lower temperature, but 20 minutes later wheel starts to heat again. Sometimes heats even on 0 ????? bad 0-10 swith on driver side or something in the steering wheel? anyone have this?
The way I read the operation for the steering wheel is that it is independent of the seats. It is on its own external circuit depending on a number of external factors, like internal and external temp. Mine comes on when its cold, but I never felt it to be too "hot". something with some sensor may be wrong, but I don't think it is tied to the seat temp.
The wheel will shut off once the cabin gets up to temp.
I couldn't live without the heated steering wheel, now that I have one. Pure delight on those frosty mornings!
And yes the heated seat switch has nothing to do with the steering wheel.
That's how it worked in the 04 I just bought. Haven't read the manual though. I will do that to confirm. Interesting that the right button didn't do anything with the lights when I was playing with it. Maybe there is a problem with mine... I will check and update when I get delivery. I AM getting old......
Moderator !x4
its ok, this was a big thing when we found the buttons, in daylight you can't see them do anything. I would suspect one of your is broken so unless you only have one arm you should be ok
me to
me to
I wasn't aware of that. Not sure they have that option anymore. I haven't seen it referenced anywhere so far. I'll check it out.
The switch I was talking about is in the center bottom back of wheel and turns the steering wheel heat on and off. A message pops up on the dash when you turn it on or off but no long term indication. I have yet to have it shut off unless I do so manually. It gets pretty hot and yes it is a nice option. I didn't think much of it until I had it.
