Difference between Porsche Cayenne and VW Touareg
Front brakes are different between your Touareg and Cayenne. Your V8 Touareg, along with the V6 Cayenne and Touareg, have 330mm front brake rotors. The Cayenne S, Turbo, and Touareg V10 TDI have 350mm front rotors. They all have the same 330mm rear rotors. Your air suspension V8 Touareg along with my V10 have slightly smaller hollow sway bars than Cayenne Turbo hollow bars. Fronts on the air suspension Touaregs are 34.6mm and on the Cayenne Turbo are 37mm. I don't know what the rear Treg bars are size wise but the Cayenne Turbo bar is 25mm. Cayenne Turbo sway bars and bushings, front and rear, can be had for around $300 and change from Sunset.
Sooo... after one week with the Turbo:
The instrument cluster has a much better center display and uses colour much better. I like it.
The turn signal indicators are in a wierd place. On way opposite sides of the gauges. Don't like that so much. The Treg has turn signals in the mirrors. Did the Cayenne not have this in 04? Option? I use the ones in the mirror to make sure I have the signal on as I am changing lanes (I have to look there anyway) Just a convenience thing.
The power is intoxicating. I have a HUGE smile every time I get on the loud pedal.
The Treg has better storage than the P!g. the one on the center of the dash is super convenient for sunglasses. Yes the pepper has the little flippy thing, and it would be great if I didn't wear normal glasses, but because I have to swap I like the center dash holder much better. Also better for my phone.
The leather covered dash and door panels are a really nice touch and the seats leather is a much better quality than the VW. Smells better too. lol
Clearly Porsche was resisting cup holders for the Cayenne.....
VW put light controls for the ambient on the MFD instead of buttons on the overhead console. I like the MFD better. VW also chose red as the back lighting which is much better than the yellow Porsche chose.
Porsche mounted the cargo cover to the seats instead of the side panels. This is good and bad. If you just want the large side down you cannot (that I can see now, but didn't look that hard)[bad] but when you put both seats down it is automatically stored.[good]
TPMS is an option? Surprising considering the top speed of the vehicle. One less thing to fix, but I liked it on the treg. With low profile tires it is more difficult to sense low pressure. With ****ty roads one can never be sure until you drive a couple of hundred meters.....
That's it so far, at least off the top of my head....
Oh ya. it does use more fuel than the V8 Treg, Not a huge amount, but that might be all the full throttle acceleration I have been doing
TPMS is not an option, it's been mandated by the NHSTA for all vehicles manufactured after 9/1/2007. There's an entire section in the MFD dedicated to TPMS, and I'm pretty sure it's on the CAN bus as well. When I traded my Touareg for a Cayenne, I was disappointed at the smaller size of the center console display screen and that the cargo door cannot be closed remotely. And the Car-Go mat from the Touareg didn't fit the Cayenne. But I've learned to live with the small stuff, as overall the Cayenne is a helluva lot more car than is the Touareg.
//greg//
//greg//
My fingers have been connected to my brain (as a convenience thing) for a long time. They conveniently communicate back and forth about the operating position of the turn signal lever.
I'm sure if you carry a ton of crap around there are more places to put it in a Touareg. But are they as secure for sporty driving?
It also gets the partition out of the way instead of having a random floating beam in the middle of your cargo space.
I'd be curios to hear how they compare after you've had it a few years.
Or a normal place and the ones on the Touareg are in a weird place. You just got used to the other ones
Why would you need to verify that you turned on a turn signal?
Ya mine too, but I guess I just like blinking lights.....lol
I wouldn't say the Touareg storage is "better". Dash storage works if you don't have "intoxicating power"
Tis true, but it is my DD, so I must try and contain my spirit.
Not a ton, but the small amount works with the spaces VW gave me. Just something I will have to get used to.
With a proper cup the cup holders are genius!! They hold my coffee cup in place during the most spirited of driving but allow for easy removal to take a drink!
Actually I have almost exclusively given up eating and drinking in the car. So not a huge issue, but when I do need it it is usually in a larger cup or bottle.
I've had several VW and Audi with the red light. IMO its much easier to see things with the yellow and not as hard on the eyes. (The red light not effecting night vision has been proven a myth) the yellowish tone in the Cayenne seems much closer to a natural shade.
I am not 100% convinced of this. Either way there is nothing I can do. The touareg dash seems much nicer at night (the instrument cluster is NOT red but a white. Everything seems crisper on the Treg. But again not a huge issue
Audi does this too. It allows the cargo/pet partition two locations. When you put the seats down you can raise the cargo/pet partition up behind the front seats!
Yes. That part is nice. Not a huge deal either, as I usually have cargo or passengers. Not both.
The sensors might be dead/missing/turned off.
In the treg it had A) a display on the menu and B) an alarm when a tire was low. These tires definately don't have the sensors, but not sure if the car came with it or not. Will have to do some searching.Anyone know the option code for TPMS?
No not everything. The transmissions are the same. The body (except front hood/fenders/bumper and rear hatch/bumper are the same. Same HVAC unit/ same air ride suspension (if you have it). Same body control modules (keyless entry windows and airbags and others). Same seat frames and controls (although coverings are different). Many other things I haven't remembered off the top of my head.
So it is not everything. But the price most definitely is!
Not quite. The body floor pan is the same, but the body is actually different. You can't for example bolt Cayenne doors or hatch onto a Touareg body. Touareg glass won't fit in a Cayenne.
2.9. What components do the Touareg and Cayenne share?
The Cayenne and Touareg share the same chassis, transmission, AWD system, suspension, windshield, doors, and some sheet metal.
I can't confirm the doors from personal experience but can confirm that the windscreen is the same, I had one fitted to my 2005 CTT
Option code for TPMS is I7K4.
From Touaregfaq.com
Also. The suspension is "similar" but not " the same. The transmission maybe the same unit but tuned the same or different internally? Audi/Porssche/VW/BMW all use variations of the "same transmission" across lots of platforms. But tune each differently for the engine and car it's going in.
We know the torque split at the transfer case is different in the Cayenne even though it's the same basic transfer case design.
This sounds like a case of Touareg owners taking a "quick glance" at some parts and jumping to conclusions.
Think about how many body variations Porsche makes on a 911 in a single model year. Think they would simply throw new front fenders on a Touareg and call it a Cayenne?
Similar doesn't equal " the same"
