958 over head light flickering when starting ?
Hi Guys,
Is any of you expirencing this ?
When the overhead console light is on and I start the car light flickers.
Could please someone test it .. Please make sure that light is on before.
Thank u
Thank u
Hey,
Canada so its cold but it happens in garage as well![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
So I guess none else expirence this.
My bet is battery that I have on order but still would like to hear from someone
Thank you
Thank you
The V8 Porschephile
I agree with RT930. Your battery would be the first item to check. Mine will not flicker but will slightly dim and has always been like this from day one. Quite normal as high amperage draw on start as voltage drops.
If this really bothers you, try swapping your incandescent console lamp for a LED bulb (if you can find one). Chances are high that the LED will not flicker or dim on voltage drop.
