EPS Drive Shaft Clamping Center Support Now at Pelican Parts!
Basic Sponsor
The driveshaft center bearing support is used to dampen vibration and lateral movement of the driveshaft as it spins. The factory design of the rubber seems to be a bit weak for the job, usually resulting in the rubber cracking or tearing due to age and the elements. When the rubber starts to fail, you'll notice an odd vibration coming from the center console when accelerating. This vibration will only get worse over time, eventually turning into a loud knocking noise.
The factory fix for the support is to remove the driveshaft from the car, disassemble it and use a new center support (with the same rubber centered design) when reassembling it. EPS has devised a solution that does not require driveshaft removal, and does a better job of supporting the driveshaft.
We’ll walk you through the steps when replacing the driveshaft bearing support and flex disc – instructions here!
Shop now for the EPS solution – details here!
Let us know what questions you have at any time.
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
I have those same concerns too. I made sure to use thread lock on the 4 screws that hold it together as an extra measure of security. I've not seen the Lindsey piece in person, though seeing pictures of it makes me wonder why Porsche would've used a two-piece driveshaft without good reason. For that reason I went with the EPS bracket. I chose not to go for a rebuilt shaft because I don't trust Chinese auto parts and I couldn't be sure what I'd get, and didn't want to pay the price of OEM. So far so good.
