Sick of the headlight warnings
Hey all. I have an 06 S, and pretty much everything has been rock solid on it for 150K, barring any wear or maintenance items. One thing that is haunting me though, is the frequent dipped beam warning, or turn indicator warning, or cornering light warning.
At one point I got all new bulbs, cleaned each socket and connector and tried again. I will say, every socket and connector looked as clean as the day it was built, nice and shiny. Worked for a day or so then the warnings came back. The block connector in the back of the assembly is also bright and shiny clean, but I hit it with an electrical cleaner and eraser anyway, as I did the mating side. The problem still persists.
Any
ideas on what I can do to solve this once and for all other than drive it into a &#*@ Tree?
Thanks!
bob
Any
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Thanks!
bob
I've been getting the Check Dipped Beam warning on the '06 for a few months. I tried most of the fix suggestions but no help. I got tired of messing with it. It's at the dealer now, they say it's one of the front leveling sensors, waiting on the part now.
Let me know how that turns out! In my case the bulbs actually go out. Left blinker one day, then cornering light, then its the other side etc... Pull out headlight assembly, put it back in (without doing a damn thing) and its fine again for a bit. Its not like I can put in the headlight any further! And Im pretty sure Im putting the lock thing in correctly
Take a look at the pig tail connections that are at the back of the headlamp mounting assembly. I have heard of them becoming frayed and burned for some reason and shorting out causing the problems you are describing. Electrical problems are a hard thing to trace down. Mine did this when I first purchased the 06S but has been fine for the last four years. Good luck.
As a former 928 owner, there was one thing that always came up quickly from other forum members when electrical issues were afoot, electrical grounds. Clean them if possible or at least scuff them up good (loosing the bolt and retighten a couple of times). It's amazing how electrical gremlins go away when grounds are cleaned.
I know it sounds too simplistic but anyone that's owned a 928 with electrical issues at some point found it to be that darn simple.
Wish I could help. Best of luck resolving it.
been having similar issues.
i read in another thread that by ever so slightly bending the male connectors on the lamp unit it should make a firmer connection.
i have tried that and also sprayed a product that dries the area and gives a better electrical connection(cannot remember the name).
touch wood this has worked well ever since.
Replace the pigtails, if that does not do it, you probably need a new headlight.
The pigtail has the female part of the connector that will spread and loosen over time.
955 631 239 00 is the part
![](https://rennlist.com/forums/attachments/porsche-cayenne-forum/420911d1266610945-what-i-did-to-fix-check-dipped-beam-errors-and-headlights-flickering-or-going-out-img00396-20100219-1350.jpg)
