Key Fob Programming Failure
I recently bought a nice 2011 CS that came with only one key. After doing a bit of research, I used eBay to buy a second key that appears identical - exact same FCC ID, exact same part number(s). The only difference I see is that the old one says "47/10" and the new one says "36/10" which I'm guessing are the manufacturing dates in weeks/months, which places them very close.
When I dropped it at the dealer to be programmed, the service advisor said that it probably wouldn't work and that he has to enter the VIN when ordering a key and the key comes programmed from the factory, although they then have to reprogram it (whatever that means). Sure enough, they tried it and told me it wouldn't take the coding.
Does this make sense? Has anyone had luck buying a used key for a 958 and getting it reprogrammed? Any ideas on how I can get the new key to work?
Moderator !x4
Could be to do with types , I am sure there are various
Some people have purchased keys off eBay and switched the blade and the pill from a worn key but unless your really lucky PIWIS will not allow a "foreign" key to be included
Not sure if this helps but when I took delivery of my '14 981CS, the car came with only one key. My advisor told me I get two keys but the second key is ordered from Germany when a car is delivered. The key is somehow tied to the VIN and the mothership in Germany is where this happens. The process took about 10 days. Once the second key arrived, I had to schedule a visit to the dealer to have the key coded to the car. I
I'm new to Porsche so I don't yet know what's fact or fiction as I only know BMW's ways from the last 15 years of their quirks and nonsense with the computers and coding.
I have to wonder if this activity - whatever it is - at the mothership needs to either take place ( or be undone ) before your eBay key can be coded to work... Just a thought.
That was my thought too, but I didn't have a choice but to let them do whatever it was they did if I wanted that second key. I wonder of anyone taking recent delivery of a new Porsche has had a similar experience...? I also wonder if this process is valid - do some dealers simply order the spare key and code it so the customer doesn't have to wait? Ie. do the work ahead of purchase so the car is complete when a customer buys...??
I had a similar experience. My '08 came with a single key, bought a second. Indy tech was unable to program two keys, apparently the tool programs one key then stops, doesn't proceed to the second key. He does not have this problem with 911 family keys, believes there's a bug in the software. I have yet to take the car and keys to a dealer.
Kevin
Catellus Engineering
Kevin
I got Fobs off ebay one was able to be coded first was not and I was able to return for a refund.
I assume one was new and other was not.
Dealer coded them for free.
Finding a HAA, Valeo of Huff blank, was a pain, as they only sell to OEMs, not consumers.
Getting someone to cut it was a pain too as they cheap knock offs from china ruin key cutters $150 bits (knock offs are steel, OEM are a mixed metal and softer)
Answer it can be done on the cheap, but you have to work for it, I spent under $100 but only because of dealer good will, ebay hassles and tracking down key cutter.
I'm continuing to research my key (re)programming issue just 'cause I'm cheap and stubborn. I found an interesting video on YouTube that appears to show a PIWIS II tester being used to first try to reprogram a Panamera key and fail, then to "repair the immobilizer" (4:09 in the video), then to proceed to successfully program two keys. There's no sound so I might be completely misinterpreting what's going on, but it does look promising. Is there anyone here with PIWIS II experience who can weigh in on this technique? I'm half tempted to ask my dealer to try it.
I bought my P!g with only one key, so I'm following this with interest...
When I picked up my CS in December, '12, it came with one active key and one non functional key (battery was dead).
I thought a new battery would revive the second key, but no luck. Ended up taking it to the dealer for programming. They were able to get the second key to work, but I ended buying a new key too, just in case
So, if you are counting, there are three active keys and they all work.
The dealer seems to be, no pun intended, the key. :-)
