Unknow fluid leak???
Super Moderator
Needs More Cowbell
Needs More Cowbell
Larry's 04 Cayenne S is without warranty and hasn't cost a dime in repairs in many many years. I can personally testify to that fact.
Don't you read JDPowers for quality rankings?
How dare you insult the mechanical design integrity of the greatest SUV ever to set hooves...sorry, foot....on the planet.
Anything that goes wrong with a Caenne is due to owner mistakes, abuse, incorrect maintenance...not the Cayenne.
Now if you'll excuse me, ths thread has convinced me to rush to my local Porsche dealer and buy another Cayenne.
Gents,
The car is in the shop and I just a preliminary update from the Tech. He reckons that the leaks (ATF and engine oil) are coming from the respective coolers sitting behind the radiator. In order to get to them, he has to remove the front bumper. That got me thinking about 2 things...
1. The front and rear bumpers were removed a couple of weeks ago for painting. The car did not leak before that, so am wondering if they could have damaged something in the process. Anythoughts on this?
2. Is there any other maintenance item that is worth taking care of while the bumper is off, e.g. serpentine belt?
Thanks again.
Thanks again.
Gents,
Thanks again.
Thanks again.
If there is a way to prove the bumper was installed incorrectly, that will go a long way toward having the paint shop pick up the cost of the repairs.
Gents,
Just to close the loop on this one: It was indeeo the ATF cooler that was leaking. The ATF was leaking down the front of the rad and the cooling fans were sucking it through and it was creating that horrible mess under the car.
We tried to have it repaired, but this did not work. So I had to have a new cooler and new pipework, as Porsche had updated the fixings on the cooler from a threaded fitting to a push type fitting. All in all, it came to the equivalent of a $1000.
In tkaing off the front bumper, we founf enough evidence to suggest that the paint shop had not removed the bumper for painting, as they had cgarged for. That is a fight for another day...
