Q regarding Diesel engine longevity in the U.S.....
The silver jug is great, three seasons of the year. But if you experience winter temperatures below 20F, you should temporarily switch to the white jug until the threat of fuel gelling passes. It's the same as the stuff in the silver jug, but contains an anti-gel additive. Another tip; save the empty containers. It only takes about 12 ounces per 26 gallon tank. I re-use my 16 ouncers to contain a pre-measured one-tank dose. the 16 ouncer fits nicely alongside the spare in the wheel well. You might consider re-using a few of your empties to contain two pre-measured doses.
//greg//
//greg//
Except BP all the stations I've gone to so far both locally (DC area) and my trip back and forth to FL have the cetane rating posted. All I have found so far is 40 though.
I'm convinced -- just ordered a case of the product (Power Service -- Diesel Kleen + Cetane Boost) from Amazon -- QTY 12 -- 32oz -- good for 1200 gallons total or 30Kmi+ -- $77USD delivered. Here's a link to the Power Service web site that I found helpful: http://www.powerservice.com/faq/
Here's another thought. If one uses this additive, does it bring fuel quality up to European standards? And would it be prudent to extend oil changes beyond the recommended 5Kmi interval?
Oil change intervals are a function of what happens to the oil once it is in your engine. During the warranty period, I would go with whatever the manufacturer says (both oil and interval). Once the warranty is over, I would send a sample of the oil off to a lab for analysis (be sure to get a test for Total Base Number -TBN). Depending on what comes back from the lab, then you could make some informed decisions. For example, if TBN on a 5,000 mile sample was 3+ and there was no fuel contamination, and viscosity was within spec, then I would try stretching the interval out another 2,500 miles and see what happens to the next sample's results.
I try to time my fill-ups to hit area Shell stations, their D2 has a 46 rating. When traveling outside my local area, I refer to this list. I also carry Power Service next to the spare tire, for use in those occasions when 46 or higher is not conveniently available.
//greg//
//greg//
Thanks for posting the list.
You're welcome, but I can't take credit personally. It was originally posted over at myturbodiesel.com. I don't take all the numbers as gospel, but it serves as a handy general reference when traveling out of my own area.
//greg//
//greg//
